Hi, JJ,
I plot on-resistance of MOS switch using the following card in SPICE.
.probe ron=par('(v(in)-v(out))/I1(MS)')
where ron is the on-resistance of MOS swtich. v(in) and v(out) is input voltage and output voltage of that switch, respectively. MS is the MOS switch.
Make your MOS switch in normal operating mode and run a transient simulation.
Good luck
Yawei
