May 17th, 2024, 10:58pm
ion implantation for Vth adjustment (Read 2324 times)
analogic
Mar 28th, 2005, 7:23pm
it is said in some book that "ion implantation for Vth adjustment" is done after the growth of gate oxide. is it true? will it degrade the quality of the gate oxide? Thanks.
DReynolds
Scarborough ME
Re: ion implantation for Vth adjustment
Reply #1 - Mar 29th, 2005, 7:30am
Analogic, ion implantation is done several times in .13um to adjust threshold (among other things). You can get normal vt, low vt and native devices..... no, it doesn't hurt the quality of the gate oxide. If you use the lower vt or native devices, be careful to understand how much they can vary before you commit to using them.
David Reynolds
