May 15th, 2024, 7:34pm
what wrong with the CadenceIC? (Read 6955 times)
wjx197733
Feb 12th, 2006, 10:09pm
Hi, all: I count some troubles when I use CandeceIC5141.
I setup CandeceIC5141 in linux system. But when I use "Analog Enviroment", CadenceIC shows:
"*error* Unable to establish connection with SacnWave, please exit and re-start the workbench. "
I do not know why this error occurs. Help me, please!!!
bernd
Munich/Germany
Re: what wrong with the CadenceIC?
Reply #1 - Feb 13th, 2006, 1:36am
What's 'SacnWave' I assume you mean 'wavescan', if you post a
error messages in quotes people think it is the original output from the
tool and not a retyped one, so cut and paste will do it for the next time.
Could it be that you missed a part of your installation, maybe the Java
Runtime Environment.
Please check if the following directory exists
<installDir>/tools/jre         ;; link to
<installDir>/tools/jre1.42
Just a guess,
Bernd
Just another lonesome cad guy
bernd
Munich/Germany
Reply #2 - Feb 13th, 2006, 1:48am
I knew that I have seen this before somewhere. And after a quick
search at SourceLink I found the answer to it.
So this should be the original error message
Quote:
*Error* Unable to initialize WaveScan. Please exit work-bench and try again. If this error persists contact Customer Support.
Then there is a SourceLink solution for this
http://sourcelink.cadence.com/docs/db/kdb/2004/Aug/11150960.html
Which says you should update to the latest ISR of IC5141.
You can register for your own SourceLink account if you are a regular Cadence User at
https://sourcelink.cadence.com/en/signup/SignUp.jhtml
Bernd
bernd
Munich/Germany
Reply #3 - Feb 13th, 2006, 1:58am
And again.
A workaround might be to choose the old AWD as your default waveform
viewer.
Under
Analog Environment Menus
Session -> Options ...
Waveform Tool   ==  AWD
or as permanent default in your local .cdsenv file
asimenv.startup cds_ade_wftool string "awd"
Bernd
