I knew that I have seen this before somewhere. And after a quick
search at SourceLink I found the answer to it.
So this should be the original error message
Quote:*Error* Unable to initialize WaveScan. Please exit work-bench and try again. If this error persists contact Customer Support.
Then there is a SourceLink solution for this
http://sourcelink.cadence.com/docs/db/kdb/2004/Aug/11150960.htmlWhich says you should update to the latest ISR of IC5141.
You can register for your own SourceLink account if you are a regular Cadence User at
https://sourcelink.cadence.com/en/signup/SignUp.jhtmlBernd
