May 4th, 2024, 12:44pm
Pages: 1 2
Phase Noise of ECL Level Divider (Read 30121 times)
Frank Wiedmann
Munich, Germany
Re: Phase Noise of ECL Level Divider
Reply #15 - Oct 02nd, 2006, 1:57am
Ken, just to be clear: I absolutely agree with everything you wrote. As far as I can tell, both the normal and the timedomain/strobed pnoise analyses work absolutely correctly for both driven and autonomous circuits. What I am arguing against is the way the pnoise jitter analysis (which is a relatively new and separate analysis type) is currently implemented for the autonomous case. I do not think that this way is very useful and it would have been much better to implement the pnoise jitter analysis for autonomous circuits in just the same way as for driven circuits.
Reply #16 - Oct 2nd, 2006, 8:22am
I understand. I have not seen this newer version yet, but I'll make sure that Cadence reads this thread.
Vick
Reply #17 - Oct 6th, 2006, 6:04am
[quote author=timmc6 link=1158788102/0#0 date=1158788102]Hello,
Also, I am not sure if I should use an 'absolute' sweep or 'relative' sweep in PNOISE.
Hy! I'm still waiting for an answer to this question, relative or absolute? It seems to me that an Absolute Sweeptype is equivalent to a Relative one with Relative Harmonic parameter set to 0. And I think that this is the correct way of predicting the noise near the main output frequency (Is that so?). Then why some people suggests as the correct Relative Harmonic = 1 in the pnoise form of Spectre?
Thanks.
Vick
Reply #18 - Oct 6th, 2006, 10:17am
If you are using strobing, it does not matter as the noise is periodic in frequency.
neoflash
Mixed-Signal
Designer
Reply #19 - Jul 5th, 2011, 10:54am
Ken,
When you mention strobed analysis, you mean noisetype = "time-domain" or "jitter" ?
Ken Kundert wrote on Oct 6th, 2006, 10:17am:
Reply #20 - Jul 5th, 2011, 10:31pm
Yes.
neoflash
Mixed-Signal
Designer
Reply #21 - Jul 5th, 2011, 10:35pm
Ken,
It is actually a selective question. noisetype = "time domain" or "jitter".
Cheesy
Frank Wiedmann
Munich, Germany
Reply #22 - Jul 6th, 2011, 12:52am
For pnoise analysis, the timedomain and jitter noisetypes (PM jitter for autonomous circuits) are almost identical. The only difference is how you specify the strobing times. In general, noisetype=pmjitter is more useful because you specify the times by using threshold crossings. The noisetype=timedomain is the older variant, there you specify the times with respect to the result of the pss analysis.
neoflash
Mixed-Signal
Designer
Reply #23 - Jul 6th, 2011, 11:02am
Thanks for the comments.
I'm surprised that Cadence's documentation is so weak on this topic. And users have to go beyond their website to understand this basic usage information.
At least, they should provide application notes for VCO, driven circuits and PFD/CP. The step by step setup procedures and result processing.
Frank Wiedmann wrote on Jul 6th, 2011, 12:52am:
neoflash
Mixed-Signal
Designer
Reply #24 - Jul 6th, 2011, 11:25am
Removed wrong question.
« Last Edit: Jul 6th, 2011, 11:01pm by neoflash »
neoflash
Mixed-Signal
Designer
Reply #25 - Jul 6th, 2011, 12:01pm
When I was trying to convert the Jee (Sec/Hz) in "PM jitter" mode to phase noise in "source" mode, I found they are nicely offset by 112dBc.
I was using below equation for this conversion:
  multiple Jee with term "sqrt( 2*pai*Fo )" and do 20*log10() to get the expected phase noise curve.
However, the calculated from Jee is 112dB lower than phase noise from source mode. I'm not sure which step go wrong.
- Neo
Frank Wiedmann
Munich, Germany
Reply #26 - Jul 6th, 2011, 3:03pm
Have you carefully read the thread at http://www.designers-guide.org/Forum/YaBB.pl?num=1224609785 ? You will probably find the answers to most of your questions there.
neoflash
Mixed-Signal
Designer
Reply #27 - Jul 6th, 2011, 4:25pm
Oops. Correct equation but one term square rooted by mistake.
It turns out that Jee converted will be DSB while source mode is SSB. Jee is 3dB higher.
I think Cadence should follow the same guideline for DSB and SSB for all modes.
Pages: 1 2
