May 21st, 2024, 11:12am
Pages: 1 2
UltraSim simulation failed (Read 3963 times)
Pavel
Lausanne/Switzerland
Nov 15th, 2006, 6:39am
Hello
Trying to run UltraSim simulation from Virtuoson Schematic Editor, I receive the following message in si.log file
Running simulation in directory: "/dir1/proj/UltraSim.run1".
Begin Incremental Netlisting Nov 15 15:01:22 2006
ERROR: Netlister: unable to descend into any of the views defined in the view list: "spectre cmos_sch cmos.sch schematic veriloga" for instance I1 in cell TB_0.
Either add one of these views to: Library: 90131BA_DIGITAL Cell: test_case0 or modify the view list to contain an existing view.
End netlisting Nov 15 15:01:22 2006
"Netlister: There were errors, no netlist was produced."
Simulation did not complete.
Instance I1 in TB_0 cell is verilog testbench, which I imported using icms-log/File/Import feature.
Where can I find view list to add functional view?
Thanks in advance
Pavel
bernd
Munich/Germany
Re: UltraSim simulation failed
Reply #1 - Nov 15th, 2006, 7:25am
Did you run a pure UltraSim simulation?
As far as I know pure UltraSim is not able to run mix-signal simulations.
What I know is that you can use a VCD file as stimulus.
You should rather use the AMS designer with UltraSim as analog solver.
The view list can either be changed in the Hierarchy Editor if you
use a config view or in the Analog Environment "Setup -> Environmet...".
But I don't think this will help you for pure UltraSim.
Bernd
Just another lonesome cad guy
Pavel
Reply #2 - Nov 15th, 2006, 8:01am
Thanks Bernd
What "pure"  UltraSim simulation means?
Before I run UltraSim in this manner
1. Virtuoso Schematic Editor -> Tools -> Simulation -> UltraSim
   UltraSim menu appears
2. UltraSim -> Netlist/Simulate...
Message cited in my previous message was result of these actions
Now I changed approach:
1. Virtuoso Schematic Editor -> Tools -> Analog Envirnment
2. Analog Envirnment -> Setup -> Simulator/Directory/Host...
   - Simulator/Directory/Host... -> Simulator -> UltraSim
3. Analog Envirnment -> Setup -> Environment
   Switch View List: spectre cmos_sch cmos.sch schematic functional
   Stop View List: symbol
4. Choose Analyses -> tran, Stop Time: 10m
5. Analog Envirnment -> Netlist and Run...
This provoke the following message in icms-log window:
Netlist Error: The HDL cell-view "90131BA_DIGITAL" "test_case0" "functional" does not have view-specific
           simulation data.  To create the data please open and save the view.
           You may also update the view by executing the following SKILL command:
           ahdlUpdateViewInfo("90131BA_DIGITAL" ?cell "test_case0" ?view "functional")
End netlisting Nov 15 16:47:53 2006
test_case0 is just verilog-coded testbench.
What this error means?
Regards.
Pavel
bernd
Munich/Germany
Reply #3 - Nov 16th, 2006, 12:21am
Pavel,
I'm pretty certain that you can not simulate any digital HDL,
Verilog or VHDL, with UltraSim and pure meant in that context ony
UltraSim.
For simulating Verliog  with UltraSim you have to switch to AMS Desigenr
and choose UltraSim as the analog sovler. (Very costly in terms of licenses)
Didn't you have a transistor level representation of your Verilog block?
Then you can choose a fast simulation mode in UltraSim for it, digital accurate
or digital fast, this may help in term of simulation speed.
Bernd
Pavel
Reply #4 - Nov 16th, 2006, 12:39am
Thank you for answer Bernd
The total design is complex. Verification with Spectre will take some days.
So, I try to test it using UltraSim.
It (design) consists of 2 parts - digital (schema generated from synthesis tool) and analog (made in Virtuoso Schematic Editor).
Digital stimuli is coded in verilog (test_case0 module).
Trying to validate UltraSim simulation (it's first time I try to use it) I didn't include analog part.
So for the moment my schema consists of 2 blocks - stimuli (verilog code) and digital part (schema generated from synthesis tool).
I don't have transistor level representation of verilog block as it is just stimuli.
Change to AMS Designer means use AMS PlugIn in Hiearchy Editor?
Regards.
Pavel.
bernd
Munich/Germany
Reply #5 - Nov 16th, 2006, 1:56am
Yes , but depending on your your design flow is set up you might also
be able to use AMS Designer out of the Analog Environment.
Quote:
So for the moment my schema consists of 2 blocks - stimuli (verilog code) and digital part (schema generated from synthesis tool). I don't have transistor level representation of verilog block as it is just stimuli.
What does the digital part contain, if it is from the synthesis, must be
a gate level netlist? What's below the gates? Should be some transistors?
Bernd
Pavel
Reply #6 - Nov 16th, 2006, 2:51am
How? In Analog Environment window I found nothing concerning AMS.
Gates are vendor library gates. Sure,  there should be gate level netlists for them.
The vailable views are: symbol, msps, layout, extracted, cmos_sch, abstract.
Regards.
Pavel.
bernd
Munich/Germany
Reply #7 - Nov 16th, 2006, 3:16am
Under "Simulation -> Simulator/Directory/Host".
If 'ams' is not present there it's not setup to be used inside
ADE.
'cmos_sch' should be the transistor level representation of
your gates.
It makes me wonder why it does not work with the  initial view list
"spectre cmos_sch cmos.sch schematic veriloga" under UltraSim.
Maybe you still have the get the Verilog stimuli
into a VCD file to simulate with UltraSim alone.
Bernd
Pavel
Reply #8 - Nov 16th, 2006, 3:44am
ADE.
Yes it does present Setup -> Simulator/Directory/Host... -> Simulator -> ams.
When I click on Ok, following message appears in icms-log window:
*Error* You must be viewing a 'config' viewType to run Artist with ams.
But I have config view for this cell..?
your gates.
Yes, its true
If you mean Switch View List (Setup->Enviroment) I think it's due to the fact that
my stimuli block is in verilog (functional view).
Verilog stimuli is huge, so this conversion would be combersome.
Regards.
Pavel.
bernd
Munich/Germany
Reply #9 - Nov 16th, 2006, 4:38am
You must nor only have it, you should work with it,
means you should start ADE out of the schematic representation of
your config view, best is have both open the HED and the schematic
representation. You were prompted what to use if you try to open
the config view.
I guess there could be a kind of automatic conversation with ncsim.
To clarify things
- If you want to work with UltraSim as analog solver within AMS
 Designer you don't have to use a VCD file for you stimulus.
 The the Verilog stimulus is solved by the nc part of AMS Desigenr.
- If you want to use UltraSim as Fast Spice Simulator alone, it does
 not accept Verilog code and you have to translate your stimulus somehow.
 Best bet is in my opinion VCD.
Bernd
Pavel
Reply #10 - Nov 16th, 2006, 7:02am
Ok, now it's clear, thanks.
I just tried this approach.
1. Run config view (Hierarchy Editor (HE) + Virtuoso Schemaic Editor (VSE))
2. Run ADE from VSE.
3. In Setup -> Simulator/Directory/Host... -> Simulator choosed ams simulator
4. Specified simulation time.
5. Run simulation.
Compilation/netlisting was OK apart from many warnings like below (is it important?).
\w *WARNING* Cannot open pc.db for ("D_CELLS" "DFRS" "functional").
\w      Hierarchy below (90131BA_DIGITAL.TB_0:schematic)I0.(90131BA_DIGITAL.mlx90131_topdig:schematic)u_
core_u_atpg_top_u_oper_u_send_fsm_FSendS_reg_1.(D_CELLS.DFRS:functional) will not be expanded.
Elaboration stopped with strage error:
ncelab: *F,DLNFS: Packed library for '90131BA_simulations' was either corrupt or the file system cache consistency check failed. To correct the problem, remove the packed library, and recompile. If the problem persists, contact Cadence Design Systems.
'90131BA_simulations' is library where our Spectre simulations are stocked. It isn't corrupted as we use it with Spectre.
Ok, I decided to transfer cells in other project (PROJ2 for facility).
In PROJ2 I did following actions:
1. Put reference to PROJ1 test_lib library in cds.lib file of PROJ2
2. Open Library Manager and copied  cells from PROJ1 test_lib library into PROJ2 test_lib library
3. Removed reference to PROJ1 test_lib from PROJ2 cds.lib file.
Maybe there is more smart approach to transfer cells between libraries, but I don't know it.
In anyway it doesn't work. Elaborator couldn't recognize transferred cells. What I should do - recreate manually all cells in PROJ2?
Regards.
Pavel.
bernd
Munich/Germany
Reply #11 - Nov 16th, 2006, 7:40am
Can you do what the error message suggested.
- cd to into the physical path of your library
- remove the *.pak files
- try to recompile the design
Bernd
Pavel
Reply #12 - Nov 16th, 2006, 8:43am
.pak file is removed.
Now the situation is as follows:
icms-log:
Failed to elaborate ("90131BA_DIGITAL" "TB_0" "config").
ncelab.log:
ncelab: *E,NOUNIT: Unable to find a unit named '90131BA_DIGITAL' in the libraries.
ncelab: *E,NOUNIT: Unable to find a unit named '.TB_0:config' in the libraries.
TB_0 is the top-level testbench. It has schematic and config views. The last one I used to run simulation.
'90131BA_DIGITAL' is the library where all cells are situated.
What mean these elaborator errors?
Regards.
Pavel.
bernd
Munich/Germany
Reply #13 - Nov 16th, 2006, 9:10am
Sorry no more glue, just can post you what nchelp returns
Bernd
%>nchelp ncelab NOUNIT
nchelp: 05.70-s001: (c) Copyright 1995-2006 Cadence Design Systems, Inc.
ncelab/NOUNIT =
       The specified unit does not exist in the libraries. Please check
       the name of the design unit and make sure that it has been
       compiled before rerunning ncelab. Another possibility is that the
       unit not found in the libraries has been compiled with a different
       version of the software. For example, the unit may have
       been compiled by the 32-bit software version but the current
       software version being used is the 64-bit software version.
       One more reason could be that the user is trying to elaborate the
       shell output, which is not allowed.
Pavel
Reply #14 - Nov 21st, 2006, 1:51am
Finally the problem was resolved.
It was suffucient to put cmos_sch view before functional in HE view list.
So I succeded to simulate my design. But one incertitude stays.
When I was controlling execution I didn't see UltraSim in the list of processes (prstat utility), but only ncsim.
My actual design contains 2 parts - stimuli (coded in verilog) and digital part in the form of structural-gate transistor-level netlist from synthesis tool.
I thougt that ncsim is "responsible" for stimuli and UltraSim - for digital part.
Why I see only ncsim in the list of processes.
Regards.
Pavel.
Pages: 1 2
