Quote:*Error* You must be viewing a 'config' viewType to run Artist with ams.
But I have config view for this cell..?
You must nor only have it, you should work with it,
means you should start ADE out of the schematic representation of
your config view, best is have both open the HED and the schematic
representation. You were prompted what to use if you try to open
the config view.
Verilog stimuli is huge, so this conversion would be combersome.
I guess there could be a kind of automatic conversation with ncsim.
To clarify things
- If you want to work with UltraSim as analog solver within AMS
Designer you don't have to use a VCD file for you stimulus.
The the Verilog stimulus is solved by the nc part of AMS Desigenr.
- If you want to use UltraSim as Fast Spice Simulator alone, it does
not accept Verilog code and you have to translate your stimulus somehow.
Best bet is in my opinion VCD.
Bernd
