May 17th, 2024, 8:16am
cgd modeling in bsim4 (Read 4162 times)
kanan
Mar 25th, 2009, 2:11am
Is the gate-drain metal-poly fringing cap modeled in BSIM4? I am running calibre and it seems to be extracting that cap  and I am wondering whether this is a case of double counting?
Re: cgd modeling in bsim4
Reply #1 - Mar 25th, 2009, 5:43am
BSIM4 has parameters to model gate to drain overlap capacitance, as well as the CF parameter to model fringing capacitance -- but you have to check your model card for the mos device to see if the foundry zeroed those out with the expectation that you'd extract values -- note that CGDO and CF have computed defaults, so if they're not in the model file, you can still get a non-zero value.
kanan
Reply #2 - Mar 26th, 2009, 2:01am
Thank you Geoffrey!
This query came from the fact that while designing a high speed VCO, the post-layout extraction is throwing up a lot of CC caps (Cdg, Cds). The values are of the order of 5fF which create enough trouble at that speed.
Now the transistors themselves are quite bare and I don't believe there is anything else in layout I can do to get rid of them.
I am not sure if these capacitances are real or a case of "double-counting" by calibre.
Any comments?
Reply #3 - Mar 26th, 2009, 6:11am
Your description makes it sound like the 5fF from Calibre is too much, which has nothing to do with possible double-counting.
