May 17th, 2024, 2:47am
capacitance in device models (Read 2550 times)
c1000
Aug 04th, 2010, 1:29pm
In physics-based device models, like BSIM models,  the parasitic capacitance is evaluated by the derivative of charge with respect to corresponding terminal voltage.
If the device is modeled as a current source and 16 or less capacitors, why not using capacitance directly but calculating charge for caps?
does charge must be evaluated for circuit simulation?
Re: capacitance in device models
Reply #1 - Aug 5th, 2010, 6:48am
c1000 wrote on Aug 4th, 2010, 1:29pm:
Yes.
Ken's book (Designer's Guide to Spice & Spectre) shows why -- charge conservation.  BSIM3/4 model the device as currents and charges -- four, one for each terminal.  I suppose you could count it differently: channel charge (split into four components), plus junction and overlap caps (which are two-terminal capacitors).
Not sure what you meant by "parasitic capacitance" -- the channel charge is not parasitic.
