Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 22
nd
, 2024, 12:35pm
Home
Help
Search
Login
Register
PM to admin
Design
Mixed-Signal Design
› Clock divider.
Previous topic
Next topic
Clock divider. (Read 3887 times)
Jacki
Clock divider.
Apr 02
nd
, 2014, 2:03pm
I want to get a clock divider as shown in the figure, does anybody know how to do it with the basic digital logic blocks like DFF, AND gate, OR gate ...
Thank you.
IP Logged
Jacki
Re: Clock divider.
Reply #1 -
Apr 2
nd
, 2014, 2:07pm
The duty cycle is not 50%, I try to use clock divider by 5, or counter to achieve it, but I failed.
IP Logged
AnalogDE
Re: Clock divider.
Reply #2 -
Apr 2
nd
, 2014, 3:28pm
This looks pretty simple. You can do it with a counter with output logic that decodes the 'count'. Logic outputs a '1' when it hits its 'count' that it decodes. Run that logic and AND it with incoming clock... That should be it.
IP Logged
Jacki
Re: Clock divider.
Reply #3 -
Apr 2
nd
, 2014, 6:29pm
Hi AnalogDE,
Thank you very much for your reply. I don't follow you very well. I will make a test tomorrow. Could you show me a logic structure (building block) as you are convenient?
IP Logged
Jacki
Re: Clock divider.
Reply #4 -
Apr 3
rd
, 2014, 12:33pm
Hi AnalogDE,
I understand what you mean, thank you.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
»» Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
