May 2nd, 2024, 10:52am
Can I filter Jitter? (Read 3561 times)
SNIKE
Jul 21st, 2014, 12:51am
Hi members,
We have a System clock running at 120MHz, it has 300pS peak to peak jitter.  :'(
I am designing a pipeline ADC and my sampling frequency is 1MHz.
I found that due to aperture uncertanity [jitter] my ADC's performance is limited.
Since my sampling frequency is much slower than my main noisy System clock, can I do somekind of filtering and create a new clean Clock?
what other methods can I use to improve jitter at low frequencies?
Thanks in advance.
« Last Edit: Jul 21st, 2014, 2:22am by SNIKE »
Re: Can I filter Jitter?
Reply #1 - Jul 21st, 2014, 11:28am
You can run a noisy clock into a PLL and get something out of the PLL that averages out the the mean value of the clock coming in, as a function of the PLL bandwidth.
Filter jitter? No.
Process a jittery clock to get something with less jitter? Yes.
I would look into cleaning up your system clock first, somewhere upstream there is a clean clock tied to a crystal.
SNIKE
Reply #2 - Jul 21st, 2014, 11:41am
Thanks for reply.
The system clock is a relaxation oscillator. I am not very familiar with clock design. But I guess relaxation oscillators are usually very noisy.
Is 300pS OK for relaxation oscillator? Is there some scope of improvement there?
"You can run a noisy clock into a PLL and get something out of the PLL that averages out the the mean value of the clock coming in, as a function of the PLL bandwidth."
Any prior publications which do this? Do I need a very accurate VCO to design this?
carlgrace
Berkeley, CA
Reply #3 - Jul 22nd, 2014, 5:34pm
SNIKE wrote on Jul 21st, 2014, 11:41am:
Any good text on PLL design will discuss this principle.  You do not need a very accurate VCO because the loop high-pass filters the VCO jitter wrt the output of the PLL.  (in this narrow sense you can filter jitter, but I'm not contradicting loose-electron).
Reply #4 - Jul 24th, 2014, 7:05pm
Get rid of the relaxation oscillator and go to a crystal based oscillator.
Before you try anything else.
Using a crystal should fix your problems.
