Nov 10th, 2026, 7:47pm
VerilogA random DC value (Read 2762 times)
Horror Vacui
Dresden, Germany
Sep 08th, 2023, 6:03am
Is there any way to generate random values with VerilogA for a SPECTRE's DC analysis?
The $random function is evaluated at every timestep. It gives a good random number during a transient analysis, but its values for DC and t=0 in transient is always the same.
In general I am curious whether something like is possible to achieve with VerilogA, because it was a surprise to me, that I found no solution.
Re: VerilogA random DC value
Reply #1 - Sep 8th, 2023, 11:24pm
There are various ways to run a statement only once.  There is the "analog initial" block or "@(initial_step)".  Just use a random function such that it gets called once, save it to a variable, and then use that variable to drive the output.
Horror Vacui
Dresden, Germany
Reply #2 - Sep 11th, 2023, 3:26am
I do not know which random function could I use. The random functions in VerilogA require a seed. Generating a random seed will have the same problem as I already have.
I've looked in different ways as well, but to no avail:
I haven't found a way to call a system function. I tried using the $simparam("systime") as a seed, but its resolution (1sec) wasn't random at all.
I also have not found (yet) a reliable way in our flow to execute a script between netlisting and simulation to insert a random value.
Therefore I would very grateful for any small working example.
Here is an example of mine:
`include "discipline.h"
`include "constants.h"
module rand_bit_simple (vout);
output vout;
electrical vout;
parameter integer seed = 21;
integer var_seed;
integer rnd;
   analog begin
      @ (initial_step) begin
        var_seed = seed; // variable is needed; updated after every step
        rnd = $random(var_seed);
      end // initial step
      V(vout) <+ rnd*1e-12;
    end //analog
Reply #3 - Sep 11th, 2023, 7:02pm
You might try reading a few bytes from /dev/random or /dev/urandom and using that as the initial seed.
You definitely need a transition function around *rnd* in your contribution statement.
