May 18th, 2024, 10:31am
Figure Causing multiple stamped connections (Read 55 times)
cAddIE
Oz
Feb 15th, 2006, 4:47pm
I am university student currently learning Cadence tools. I use DIVA for DRC, Extract and LVS.
Process : TSMC18RF (0.18um)
I am currently doing layout of an 10 phase oscillator circuit. When I run DRC on my completed layout I get no errors. When I run Extract with the "Join nets with same name" switch ON and Parasitic RC Switch SET. I get the following errors  :-/ :
Figure Causing Multiple Stamped Connections
Figure Having Multiple Stamped Connections
if i set the Parasitic RC switch OFF - that is if dont set any switches ( no parasitic extract ) I DONT get these errors or ANY errors.
My Design also passes the LVS succesfully
my design has following layout structure:
VDD Rail
BUFFER Amplifiers
GND Rail
Differential Amplifiers
VDD Rail
Buffer Amplifiers
GND Rail
I googled these error messages and I found some explanations but I dont seem to violate any that is mentioned in these expalnations. Like I have connected the GND and VDD properly.
the divaEXT doesnt like me putting 2 separate ground Contacts. my Ground contacts are M1_SUB. if put them at separate places i get this error  >:( . How do I go about resolving this issue? please help.
Re: Figure Causing multiple stamped connections
Reply #1 - Feb 18th, 2006, 6:34am
As I've been responding to this over on news:comp.cad.cadence I won't answer it here too...
