cAddIE
Oz
Hi, I am university student currently learning Cadence tools. I use DIVA for DRC, Extract and LVS. Process : TSMC18RF (0.18um) I am currently doing layout of an 10 phase oscillator circuit. When I run DRC on my completed layout I get no errors. When I run Extract with the "Join nets with same name" switch ON and Parasitic RC Switch SET. I get the following errors :-/ : Figure Causing Multiple Stamped Connections Figure Having Multiple Stamped Connections if i set the Parasitic RC switch OFF - that is if dont set any switches ( no parasitic extract ) I DONT get these errors or ANY errors. My Design also passes the LVS succesfully my design has following layout structure: VDD Rail ==================== BUFFER Amplifiers ==================== GND Rail ==================== Differential Amplifiers ==================== VDD Rail ==================== Buffer Amplifiers ==================== GND Rail ==================== I googled these error messages and I found some explanations but I dont seem to violate any that is mentioned in these expalnations. Like I have connected the GND and VDD properly. the divaEXT doesnt like me putting 2 separate ground Contacts. my Ground contacts are M1_SUB. if put them at separate places i get this error >:( . How do I go about resolving this issue? please help.
