panditabupesh wrote on Mar 20th, 2010, 3:35pm:But, if we look at the prescaler output, the frequency is changing between fclk/2 and fclk/3.
Can we say that it is periodic with respect to fclk/7.
Observe time domain waveforms considerably.
They behave periodically with time period of 7*Tclk, even if the frequency of prescaler output is changing between fclk/2 and fclk/3.
panditabupesh wrote on Mar 20th, 2010, 3:35pm:but at any time the output frequency of prescaler is no way related to fclk/7.
at any time"???
It seems you can't understand very basic theory of modulation and working mechanism of this prescaler at all.
Even simple 2-FSK signal modulated by periodic signal synchronous to carrier is also periodic.
All signals including the output of prescaler behave periodically with time period of 7*Tclk.
panditabupesh wrote on Mar 20th, 2010, 3:35pm:I am using PSS from Cadence, and the UI declares it as 'Beat Frequency'.
I am not facing any convergence issues (I have declared the beat/fund frequency = fclk/(NP+S) )
Again, don't use a term of "beat".You can get convergencve with fundamental frequency=fclk/(NP+S). So fundamental period is surely (NP+S)*Tclk.
panditabupesh wrote on Mar 18th, 2010, 7:23pm:I am facing convergence issues while doing PSS.
In your first post, you said you can't get convergence in PSS.
What value did you set as fundamental frequency of PSS ?
panditabupesh wrote on Mar 20th, 2010, 3:35pm:but I just want to be sure that in pnoise analysis I am not underestimating noise.
Show me netlists regarding signal sources, analysis statements and options statements.
Show me logfile of simulation.
