May 1st, 2024, 5:19am
MOS varactor cap value v.s. frequency (Read 6471 times)
nxing
God help the person
who help themselves
China
Apr 05th, 2013, 8:59am
I have saw people some paper mentioned that the capacitance value of a varactor (NMOS in accumulation mode) can varies with frequency, can anybody give an explanation why?
raja.cedt
Re: MOS varactor cap value v.s. frequency
Reply #1 - Apr 5th, 2013, 9:07am
read some basic text book on Mosfet theory, basically carriers need sometime to reach channel hence for higher frequency of operation charge carrier will not reach the channel and lesser capacitance.
Raj.
nxing
God help the person
who help themselves
China
Reply #2 - Apr 5th, 2013, 9:38am
Hi Raj
Thanks for your reply. Actually, that was what I thought. However, please refer to the following paper and in Fig 3 (the plot of measured AMOS varactor at different frequency), I found it's non-monotonic. that puzzled me.
raja.cedt
Reply #3 - Apr 5th, 2013, 9:55am
hello,
Please don't attach any publications here. I saw fig 3 it is monotonic, see some devices depends on their on their fabrication type there are several up and down's in the CV curve like Accumulated mosfet which is monotonic where as normal mosfet will have non-monodic due to region change.
Raj.
nxing
God help the person
who help themselves
China
Reply #4 - Apr 5th, 2013, 10:16am
Hi Raj,
Thanks for remind for the publication.
When you looked at the figure 3b. Cap value is monotonic on bias voltage. However, for the same bias value, cap value is not monotonic on frequency, for example, when vbias=1v, it has C(55GHz)>C(5GHz)>C(1MHz)>C(20GHz).
If considering charge travel time, I would think that the higher the frequency, the smaller cap it will have, is that correct?
Norman
